vserver vscan scanner-pool servers show
PDF of this doc site
Creating your file...
Display list of servers
The vserver vscan scanner-pool servers show
command displays the list of servers of the Vscan scanner pools belonging to the Vserver. If you do not specify any parameters, the command displays the following information about all scanner pools:
Vserver name
Scanner pool
List of servers
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the scanner pools for the specified Vserver.
[-scanner-pool <Scanner pool>]
- Scanner Pool-
If you specify this parameter, the command displays information only for the specified scanner pool.
[-servers <IP Address>,…]
- List of IPs of Allowed Vscan Servers-
If you specify this parameter, the command displays information only about the scanner pools that have the specified IP address or IP addresses.
[-hostnames <text>,…]
- List of Host Names of Allowed Vscan Servers-
If you specify this parameter, the command displays information only about the scanner pools that have the specified host name or host names.
The following example displays the list of servers of all scanner pools.
cluster1::> vserver vscan scanner-pool servers show Vserver Scanner Pool Servers --------------- ----------------- -------------------------------------------- vs1 SP 1.1.1.1, 10.72.204.27 vs2 p1 10.72.204.29 6 entries were displayed.
The following example displays the list of servers and host names of all scanner pools.
cluster1::> vserver vscan scanner-pool servers show -instance Vserver: vs1 Scanner Pool: SP List of IPs of Allowed Vscan Servers: 1.1.1.1, 10.72.204.27 List of Host Names of Allowed Vscan Servers: 1.1.1.1, vmwin204-27.fsct.nb Vserver: vs2 Scanner Pool: p1 List of IPs of Allowed Vscan Servers: 10.72.204.29 List of Host Names of Allowed Vscan Servers: vmwin204-29.fsct.nb 2 entries were displayed.
