volume expand
Expand the size of a volume by adding constituents
The volume expand command allows the user to increase the size of a FlexGroup by adding constituents. The size of the new constituents is determined by the size of the smallest existing constituent. This command only applies to FlexGroup volumes.
-vserver <vserver name>- Vserver Name-
This parameter can be used to specify the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This parameter specifies the volume for which the user wants to expand.
[-aggr-list <aggregate name>,…]- List of Aggregates for FlexGroup Constituents-
Specifies an array of names of aggregates to be used for new FlexGroup constituents. Each entry in the list will create a constituent on the specified aggregate. An aggregate may be specified multiple times to have multiple constituents created on it.
[-aggr-list-multiplier <integer>]- Aggregate List Repeat Count-
Specifies the number of times to iterate over the aggregates listed with the
-aggr-listparameter when expanding a FlexGroup. The aggregate list will be repeated the specified number of times. Example:
-aggr-list aggr1,aggr2 -aggr-list-multiplier 2
will cause four constituents to be created in the order aggr1 , aggr2 , aggr1 , aggr2 . The default value is 1.
[-foreground {true|false}]- Foreground Process-
If
falseis specified for this parameter, the command runs as a job in the background. Iftrueis specified, the command will not return until the operation is complete. The default value istrue.
The following example increases the size of a FlexGroup by adding 3 constituents:
cluster1::> volume show -vserver vs1 -volume flexgroup -fields size
vserver volume size
vs1 flexgroup 180TB
cluster1::> volume expand -vserver vs1 -volume flexgroup -aggr-list aggr1,aggr2,aggr3
Warning: The following number of constituents of size 20TB will be added to
FlexGroup "flexgroup": 3. Expanding the FlexGroup will cause the state of
all snapshots to be set to "partial". Partial snapshots
cannot be restored.
Do you want to continue? {y|n}: y
[Job 52] Job succeeded: Successful
vserver volume size
vs1 flexgroup 240TB
The following example increase the size of a FlexGroup by adding 6 constituents using the -aggr-list-multiplier :
vserver volume size
vs1 flexgroup 240TB
cluster1::> volume expand -vserver vs1 -volume flexgroup -aggr-list aggr1,aggr2 -aggr-list-multiplier 3
FlexGroup "flexgroup": 6. Expanding the FlexGroup will cause the state of
cannot be restored.
[Job 53] Job succeeded: Successful
vserver volume size
vs1 flexgroup 360TB
