volume encryption conversion pause
Pause a running volume encryption conversion operation
The volume encryption conversion pause command pauses the running encryption conversion operation on a volume.
-vserver <vserver name>- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This parameter specifies the name of the volume for which the encryption conversion operation is being paused.
[-ignore-warning {true|false}]- Ignore Warning for Conversion Pause-
If this parameter is set, the command ignores the confirmation message.
