volume encryption conversion pause
Pause a running volume encryption conversion operation
The volume encryption conversion pause command pauses the running encryption conversion operation on a volume.
-vserver <vserver name> - Vserver Name
This parameter specifies the Vserver on which the volume is located.
-volume <volume name> - Volume Name
This parameter specifies the name of the volume being encrypted.
[-ignore-warning {true|false}] - Ignore Warning for Conversion Pause
If this parameter is set, the command ignores the confirmation message.
