Command reference
security oauth2 client show
Display OAuth 2.0 Provider
The security oauth2 client show command displays the configured OAuth 2.0 Provider configuration.
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed.
| [-instance ] }
If this parameter is specified, the command displays information about all OAuth 2.0 configuration entries.
[-config-name <text>] - Configuration Entry Name
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified config-name.
[-application <OAuth 2.0 Applications>] - Application
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified application. Currently only the http application is supported.
[-issuer {scheme:​//(hostname|IPv4 Address|'['IPv6 Address']')…​}] - OAuth 2.0 Issuer
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified issuer.
[-audience <text>] - OAuth 2.0 Audience
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified audience.
[-client-id <text>] - OAuth 2.0 Client ID
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified client-id.
[-hashed-client-secret <Hex String>] - Hashed representation of client secret
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified hashed-client-secret.
[-introspection-endpoint {scheme:​//(hostname|IPv4 Address|'['IPv6 Address']')…​}] - OAuth 2.0 Token Introspection Endpoint Location
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified introspection-endpoint.
[-introspection-interval {P[<integer>D]T[<integer>H][<integer>M][<integer>S] | P<integer>W | disabled}] - OAuth 2.0 Token Introspection Refresh Interval in ISO-8601 format
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified introspection-interval.
[-remote-user-claim <text>] - OAuth 2.0 Remote User Claim
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified remote-user-claim.
[-provider-jwks-uri {scheme:​//(hostname|IPv4 Address|'['IPv6 Address']')…​}] - OAuth 2.0 Provider JSON Web Key Set Location
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified provider-jwks-uri.
[-jwks-refresh-interval {P[<integer>D]T[<integer>H][<integer>M][<integer>S] | P<integer>W}] - OAuth 2.0 JSON Web Key Set Refresh Interval in ISO-8601 format
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified jwks-refresh-interval.
[-outgoing-proxy <text>] - OAuth 2.0 Outgoing Proxy To Access External IdPs
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified outgoing-proxy.
[-use-local-roles-if-present {true|false}] - Use Local Roles, If Present
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified use-local-roles-if-present.
[-use-mutual-tls {none|request|required}] - Mutual TLS enforcement
This is the Mutual TLS setting for the OAuth 2.0 configuration. When set to required , OAuth 2.0 mutual TLS authentication is enforced for all access tokens and any token that does not have x5t#S256 property in the cnf section is rejected. The default value is request when not set, which means OAuth 2.0 mutual TLS authentication is enforced only if the x5t#S256 property is present in the cnf section of the access token. This can be disabled by setting to value none .
[-provider {basic|keycloak|auth0|adfs|entra}] - OAuth 2.0 Provider
If this parameter is specified, the command displays information only about the OAuth 2.0 configuration that match the specified Identity Provider.
The following example displays the OAuth 2.0 Provider configuration for Local Validation:
cluster1::> security oidc client show
                                Configuration Name: auth1
                                       Application: http
                          Issuer: https://issuer.example.com/
                                          Audience: -
                                         Client ID: -
                              Hashed Client Secret: -
                            Introspection Endpoint: -
                   Introspection Refresh Interval : -
                                   Use local roles: true
                Provider JSON Web Key Set Location: https://issuer.example.com/.well-known/jwks.json
                 JSON Web Key Set Refresh Interval: 1h
                                 Remote User Claim: preferred_username
                                    Outgoing Proxy: https://outgoing_proxy
                            Mutual TLS enforcement: request
                                          Provider: basic
The following example displays the OAuth 2.0 Provider configuration for Remote Introspection:
                                       Application: http
                                          Audience: -
                                         Client ID: client_id
                              Hashed Client Secret: e194e3472ee55c4202582cfbf59a03a37ef27085d2baf1b2fd7f7da3973c56fa
                   Introspection Refresh Interval : 0s
                Provider JSON Web Key Set Location: -
                 JSON Web Key Set Refresh Interval: -
                            Mutual TLS enforcement: required
                                          Provider: basic
