Command reference
storage aggregate plex online
Online a plex
The storage aggregate plex online command brings the specified plex online. The aggregate specified with the -aggregate parameter must be an online mirrored aggregate. The system will initiate resynchronization of the plex as part of online processing.
-aggregate <aggregate name> - Aggregate
Name of an existing aggregate which contains the plex specified with the -plex parameter.
-plex <text> - Plex
Name of a plex which belongs to the aggregate specified with the -aggregate parameter.
The following example brings plex0 of aggregate aggr1 online:
cluster1::> storage aggregate plex online -aggregate aggr1 -plex plex0
