Command reference
system chassis fru show
Display the FRUs in the cluster
The system chassis fru show command displays information about all the major chassis specific FRUs in the cluster. By default, the command displays the following information about all the FRUs in the cluster:
  • Chassis ID
  • FRU name
  • FRU type
  • FRU state
  • Nodes sharing the FRU
To display more details, use the -instance parameter.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays detailed information about FRUs.
[-node {<nodename>|local}] - Node
Specifies the primary node name in the cluster on which Chassis health monitor is running.
[-serial-number <text>] - FRU Serial Number
Selects information about the FRU with the specified serial number.
[-fru-name <text>] - FRU Name
Selects information about the FRU with the specified FRU name.
[-type {controller|psu|fan|dimm|bootmedia|ioxm|nvram|nvdimm}] - FRU Type
Selects information about all the FRUs with the specified FRU type.
[-name <text>] - FRU ID
Selects information about the FRU with the specified FRU unique name.
[-state <text>] - FRU State
Selects information about all the FRUs with the specified state.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Status
Selects information about all the FRUs with the specified status.
[-display-name <text>] - Display Name for the FRU
Selects information about all the FRUs with the specified FRU display name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}] - Monitor Name
Selects information about all the FRUs with the specified monitor name.
[-model <text>] - Model Type
Selects information about all the FRUs with the specified FRU model.
[-shared {shared|not_shared}] - Shared Resource
Selects information about all the FRUs with the specified sharing type.
[-chassis-id <text>] - Chassis ID
Selects information about all the FRUs in the specified chassis.
[-additional-info <text>] - Additional Information About the FRU
Selects information about all the FRUs with the specified additional information.
[-connected-nodes {<nodename>|local}] - List of Nodes Sharing the FRU
Selects information about all the FRUs with the specified node list.
[-num-nodes <integer>] - Number of Nodes Sharing the FRU
Selects information about all the FRUs with the specified number of connected nodes.
The following example displays information about all major chassis specific FRUs in the cluster:
cluster1::> system chassis fru show
Chassis ID          FRU        Type     State       Nodes Sharing the FRU
4591227214          node1       controller
                                        ok          node1
4591227214          node2       controller
                                        ok          node2
4591227214          PSU1 FRU   psu      GOOD        node1,node2
4591227214          PSU2 FRU   psu      GOOD        node1,node2
The following example displays detailed information about a specific FRU:
cluster1::> system chassis fru show -instance -fru-name "PSU1 FRU"
Node: node1
                   FRU Serial Number: XXT122737891
                            FRU Name: PSU1 FRU
                            FRU Type: psu
                            FRU Name: XXT122737891
                           FRU State: GOOD
                              Status: ok
            Display Name for the FRU: PSU1 FRU
                        Monitor Name: chassis
                          Model Type: none
                     Shared Resource: shared
                          Chassis ID: 4591227214
Additional Information About the FRU: Part Number: 114-00065+A0
Revision: 020F
Manufacturer: NetApp
FRU Name: PSU
       List of Nodes Sharing the FRU: node1,node2
     Number of Nodes Sharing the FRU: 2
