system chassis fru show
Display the FRUs in the cluster
The system chassis fru show command displays information about all the major chassis specific FRUs in the cluster. By default, the command displays the following information about all the FRUs in the cluster:
Chassis ID
FRU name
FRU type
FRU state
Nodes sharing the FRU
To display more details, use the -instance parameter.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays detailed information about FRUs.
[-node {<nodename>|local}]- Node-
Specifies the primary node name in the cluster on which Chassis health monitor is running.
[-serial-number <text>]- FRU Serial Number-
Selects information about the FRU with the specified serial number.
[-fru-name <text>]- FRU Name-
Selects information about the FRU with the specified FRU name.
[-type {controller|psu|fan|dimm|bootmedia|ioxm|nvram|nvdimm}]- FRU Type-
Selects information about all the FRUs with the specified FRU type.
[-name <text>]- FRU ID-
Selects information about the FRU with the specified FRU unique name.
[-state <text>]- FRU State-
Selects information about all the FRUs with the specified state.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]- Status-
Selects information about all the FRUs with the specified status.
[-display-name <text>]- Display Name for the FRU-
Selects information about all the FRUs with the specified FRU display name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]- Monitor Name-
Selects information about all the FRUs with the specified monitor name.
[-model <text>]- Model Type-
Selects information about all the FRUs with the specified FRU model.
[-shared {shared|not_shared}]- Shared Resource-
Selects information about all the FRUs with the specified sharing type.
[-chassis-id <text>]- Chassis ID-
Selects information about all the FRUs in the specified chassis.
[-additional-info <text>]- Additional Information About the FRU-
Selects information about all the FRUs with the specified additional information.
[-connected-nodes {<nodename>|local}]- List of Nodes Sharing the FRU-
Selects information about all the FRUs with the specified node list.
[-num-nodes <integer>]- Number of Nodes Sharing the FRU-
Selects information about all the FRUs with the specified number of connected nodes.
The following example displays information about all major chassis specific FRUs in the cluster:
cluster1::> system chassis fru show
Chassis ID FRU Type State Nodes Sharing the FRU
4591227214 node1 controller
ok node1
4591227214 node2 controller
ok node2
4591227214 PSU1 FRU psu GOOD node1,node2
4591227214 PSU2 FRU psu GOOD node1,node2
The following example displays detailed information about a specific FRU:
cluster1::> system chassis fru show -instance -fru-name "PSU1 FRU"
Node: node1
FRU Serial Number: XXT122737891
FRU Name: PSU1 FRU
FRU Type: psu
FRU Name: XXT122737891
FRU State: GOOD
Status: ok
Display Name for the FRU: PSU1 FRU
Monitor Name: chassis
Model Type: none
Shared Resource: shared
Chassis ID: 4591227214
Additional Information About the FRU: Part Number: 114-00065+A0
Revision: 020F
Manufacturer: NetApp
FRU Name: PSU
List of Nodes Sharing the FRU: node1,node2
Number of Nodes Sharing the FRU: 2
