The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nfs prepare-for-v3-ms-dos-client-downgrade
PDF of this doc site
Creating your file...
Your file is ready
(DEPRECATED)-Disable NFSv3 MS-DOS Client Support
This command is deprecated and may be removed in a future release. |
The vserver nfs prepare-for-v3-ms-dos-client-downgrade
command verifies that the NFSv3 MS-DOS client setting is disabled on all Vservers and disables the NFSv3 MS-DOS client support capability on the cluster when downgrading ONTAP to a version that does not support NFSv3 MS-DOS clients.
The following example disables NFSv3 MS-DOS client support on the Vservers.
cluster::1> vserver nfs prepare-for-v3-ms-dos-client-downgrade
