vserver peer show-all
(DEPRECATED)-Display Vserver peer relationships in detail
The vserver peer show-all command displays the following information about Vserver peer relationships:
Local Vserver name
Peer Vserver name
Local Vserver UUID
Peer Vserver UUID
Peer cluster name
Applications
State of the peering relationship
Remote Vserver name
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Local Vserver Name-
If this parameter is specified, the command displays relationships that match the specified local Vserver.
[-peer-vserver <text>]- Peer Vserver Name-
If this parameter is specified, the command displays relationships that match the specified peer Vserver.
[-vserver-uuid <UUID>]- Local Vserver UUID (privilege: advanced)-
If this parameter is specified, the command displays relationships that match the specified local Vserver UUID.
[-peer-vserver-uuid <UUID>]- Peer Vserver UUID (privilege: advanced)-
If this parameter is specified, the command displays relationships that match the specified peer Vserver UUID.
[-peer-state {peered|pending|initializing|initiated|rejected|suspended|deleted}]- Peering State-
If this parameter is specified, the command displays relationships that match the specified peer state.
[-applications {snapmirror|file-copy|lun-copy|flexcache}]- Peering Applications-
If this parameter is specified, the command displays relationships that have the specified applications.
[-peer-cluster <text>]- Peer Cluster Name-
If this parameter is specified, the command displays relationships that have the specified peer cluster name.
[-remote-vserver-name <text>]- Remote Vserver Name-
If this parameter is specified, the command displays relationships that match the specified remote Vserver.
The following example illustrates how to display Vserver peer relationships. +
cluster1::> vserver peer show-all
Peer Peer Peering Remote
Vserver Vserver State Peer Cluster Applications Vserver
lvs1.example.com
lvs2.example.com
peered cluster1 snapmirror lvs2.example.com
lvs1.example.com
pvs1.example.com
peered cluster2 snapmirror pvs1.example.com
lvs2.example.com
lvs1.example.com
peered cluster1 snapmirror lvs1.example.com
lvs3.example.com
pvs1_cluster3.example.com
peered cluster3 snapmirror pvs1.example.com
lvs1.example.com
lvs1_cluster4.example.com
peered cluster4 snapmirror lvs1.example.com
5 entries were displayed.
