ONTAP commands
vserver peer show-all
(DEPRECATED)-Display Vserver peer relationships in detail
The vserver peer show-all command displays the following information about Vserver peer relationships:
  • Local Vserver name
  • Peer Vserver name
  • Local Vserver UUID
  • Peer Vserver UUID
  • Peer cluster name
  • Applications
  • State of the peering relationship
  • Remote Vserver name
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver>] - Local Vserver Name
If this parameter is specified, the command displays relationships that match the specified local Vserver.
[-peer-vserver <text>] - Peer Vserver Name
If this parameter is specified, the command displays relationships that match the specified peer Vserver.
[-vserver-uuid <UUID>] - Local Vserver UUID (privilege: advanced)
If this parameter is specified, the command displays relationships that match the specified local Vserver UUID.
[-peer-vserver-uuid <UUID>] - Peer Vserver UUID (privilege: advanced)
If this parameter is specified, the command displays relationships that match the specified peer Vserver UUID.
[-peer-state {peered|pending|initializing|initiated|rejected|suspended|deleted}] - Peering State
If this parameter is specified, the command displays relationships that match the specified peer state.
[-applications {snapmirror|file-copy|lun-copy|flexcache}] - Peering Applications
If this parameter is specified, the command displays relationships that have the specified applications.
[-peer-cluster <text>] - Peer Cluster Name
If this parameter is specified, the command displays relationships that have the specified peer cluster name.
[-remote-vserver-name <text>] - Remote Vserver Name
If this parameter is specified, the command displays relationships that match the specified remote Vserver.
The following example illustrates how to display Vserver peer relationships. +
cluster1::> vserver peer show-all
            Peer        Peer                           Peering        Remote
Vserver     Vserver     State        Peer Cluster      Applications   Vserver
lvs1.example.com
            lvs2.example.com
                        peered       cluster1          snapmirror     lvs2.example.com
lvs1.example.com
            pvs1.example.com
                        peered       cluster2          snapmirror     pvs1.example.com
lvs2.example.com
            lvs1.example.com
                        peered       cluster1          snapmirror     lvs1.example.com
lvs3.example.com
            pvs1_cluster3.example.com
                        peered       cluster3          snapmirror     pvs1.example.com
lvs1.example.com
            lvs1_cluster4.example.com
                        peered       cluster4          snapmirror     lvs1.example.com
5 entries were displayed.
