Command reference
statistics-v1 nfs show-nlm
(DEPRECATED)-Display NLM statistics
The statistics-v1 nfs show-nlm command displays the following statistics about the Network Lock Manager (NLM) on each node in the cluster:
  • Result of the operations (success or failure)
  • Total number of null operations
  • Total number of test operations
  • Total number of lock operations
  • Total number of cancel operations
  • Total number of unlock operations
  • Total number of granted operations
  • Total number of share operations
  • Total number of unshare operations
  • Total number of nmlock operations
  • Total number of freeall operations
  • Total number of all the above operations
This command is designed to be used to analyze performance characteristics and to help diagnose issues.
Note This command requires an effective cluster version earlier than ONTAP 9.0. Data for nodes running ONTAP 9.0 or later is not collected, and will not be displayed. Use the statistics show-object nlm command instead.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node (privilege: advanced)
If you specify this parameter, the command displays statistics only for the specified node.
[-result {success|failure|all}] - Result (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified result (success/failure/all).
[-null <Counter with Delta>] - Null Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of null operations.
[-test <Counter with Delta>] - Test Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of test operations.
[-lock <Counter with Delta>] - Lock Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lock operations.
[-cancel <Counter with Delta>] - Cancel Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of cancel operations.
[-unlock <Counter with Delta>] - Unlock Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of unlock operations.
[-granted <Counter with Delta>] - Granted Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of granted operations.
[-share <Counter with Delta>] - Share Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of share operations.
[-unshare <Counter with Delta>] - Unshare Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of unshare operations.
[-nmlock <Counter with Delta>] - NmLock Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of nmlock operations.
[-freeall <Counter with Delta>] - FreeAll Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of freeall operations.
[-total <Counter64 with Delta>] - Total Operations (privilege: advanced)
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of total operations.
The following example displays statistics about the NLM for a node named node1:
cluster1::*> statistics-v1 nfs show-nlm -node node1
Node                 Value         Delta
node1             --------success-------
Null:                    0             -
Test:                    0             -
Lock:                    2       0/s:23s
Cancel:                  0             -
Unlock:                  1       0/s:23s
Granted:                 0             -
Share:                   0             -
Unshare:                 0             -
NmLock:                  0             -
FreeAll:                 0             -
Total:                   3       0/s:23s
Node                 Value         Delta
node1             --------failure-------
Null:                    0             -
Test:                    0             -
Lock:                    0             -
Cancel:                  0             -
Unlock:                  0             -
Granted:                 0             -
Share:                   0             -
Unshare:                 0             -
NmLock:                  0             -
FreeAll:                 0             -
Total:                   0             -
