Command reference
vserver config-replication show
Display Vserver configuration replication resume time
The vserver config-replication show command displays the time at which the configuration replication resumes for the Vserver.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-vserver <vserver>] - Vserver (privilege: advanced)
If you specify this parameter, the command displays resume time for the specified Vserver.
[-resume-time <MM/DD/YYYY HH:MM:SS>] - Replication resume time (privilege: advanced)
If you specify this parameter, the command displays Vservers whose configuration replications are resumed at the specified resume time.
cluster::> vserver config-replication show
                                    Replication
                      Vserver       Resume Time
                      vs1           12/9/2014 03:18:48
