vserver config-replication show
Display Vserver configuration replication resume time
The vserver config-replication show command displays the time at which the configuration replication resumes for the Vserver.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver (privilege: advanced)-
If you specify this parameter, the command displays resume time for the specified Vserver.
[-resume-time <MM/DD/YYYY HH:MM:SS>]- Replication resume time (privilege: advanced)-
If you specify this parameter, the command displays Vservers whose configuration replications are resumed at the specified resume time.
cluster::> vserver config-replication show
Replication
Vserver Resume Time
vs1 12/9/2014 03:18:48
