vserver config-replication show
Display Vserver configuration replication resume time
The vserver config-replication show
command displays the time at which the configuration replication resumes for the Vserver.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Vserver-
If you specify this parameter, the command displays resume time for the specified Vserver.
[-resume-time <MM/DD/YYYY HH:MM:SS>]
- Replication resume time-
If you specify this parameter, the command displays Vservers whose configuration replications are resumed at the specified resume time.
cluster::> vserver config-replication show Replication Vserver Resume Time ----------- ------------------ vs1 12/9/2014 03:18:48
