vserver config-replication show
Display Vserver configuration replication resume time
The vserver config-replication show command displays the time at which the configuration replication resumes for the Vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver>]- Vserver (privilege: advanced)
If you specify this parameter, the command displays resume time for the specified Vserver.
- [-resume-time <MM/DD/YYYY HH:MM:SS>]- Replication resume time (privilege: advanced)
If you specify this parameter, the command displays Vservers whose configuration replications are resumed at the specified resume time.
cluster::> vserver config-replication show
                                    Replication
                      Vserver       Resume Time
                      vs1           12/9/2014 03:18:48
 PDFs
PDFs
