vserver nfs prepare-for-v3-ms-dos-client-downgrade
(DEPRECATED)-Disable NFSv3 MS-DOS Client Support
This command is deprecated and may be removed in a future release. |
The vserver nfs prepare-for-v3-ms-dos-client-downgrade
command verifies that the NFSv3 MS-DOS client setting is disabled on all Vservers and disables the NFSv3 MS-DOS client support capability on the cluster when downgrading Data ONTAP to a version that does not support NFSv3 MS-DOS clients.
The following example disables NFSv3 MS-DOS client support on the Vservers.
cluster::1> vserver nfs prepare-for-v3-ms-dos-client-downgrade
