Command reference
storage stackmon modify
Modify stackmon information
The storage stackmon modify command modifies stackmon.
-node {<nodename>|local} - Node (privilege: advanced)
This parameter specifies the node on which to modify stackmon.
[-paused {true|false}] - Paused (privilege: advanced)
This parameter specifies whether stackmon is paused. If set to true, stackmon will not respond to any topology changes.
[-reset-timer <true>] - Reset Stackmon Timer (privilege: advanced)
This parameter resets stackmon's timer, which will trigger it to check for and resolve any stack ID conflicts.
[-refresh-shelf-table <true>] - Refresh Shelf Table (privilege: advanced)
This parameter refreshes the table used by storage shelf commands.
The following example pauses stackmon on all nodes.
cluster1::> storage stackmon modify -node * -paused true
The following example triggers stackmon on all nodes.
cluster1::> storage stackmon modify -node * -reset-timer true -paused false
