Command reference
metrocluster modify
Modify MetroCluster configuration options
The metrocluster modify command modifies MetroCluster parameters for nodes in the MetroCluster configuration.
{ -auto-switchover-failure-domain <MetroCluster AUSO Failure Domain> - Cluster Level AUSO Option
This parameter specifies the configuration of automatic switchover.
The parameter values are:
  • auso-on-cluster-disaster - triggers an unplanned switchover if all nodes in a DR cluster are down.
  • auso-disabled - automatic switchover is disabled.
A change to the parameter affects only the local cluster where the metrocluster modify command is used.
| -enable-unmirrored-aggr-deployment {true|false} - Enable or Disable Unmirrored Aggregate Deployment
Enable or disable unmirrored aggregates deployment
| -is-encryption-enabled {true|false} - Is Encryption Enabled
This parameter is used to enable or disable NVLog and Storage data encryption in MetroCluster over IP configuration.
-dr-group-id <integer> - DR Group ID
This parameter identifies the DR group where encryption is being enabled or disabled.
| [-allow-auto-forced-switchover {true|false}] - Allow Automatic Forced Switchover (privilege: advanced)
This parameter is used to enable automatic forced switchover on node failures.
All nodes in a MetroCluster configuration must have this option enabled to enable automatic forced switchover on failure.
| -node-name {<nodename>|local} - Node to Change the Option On }
This parameter is used to specify the node in the cluster for which the parameter needs to be modified.
[-automatic-switchover-onfailure <true>] - Node Level AUSO Option (privilege: advanced) }
This parameter is used to enable automatic switchover on node failures. The automatic-switchover-onfailure parameter is not supported on a MetroCluster over IP configuration.
All nodes in a MetroCluster configuration must have this option enabled to enable automatic switchover on failure.
The following example shows the output of MetroCluster modification done on a node:
clusA::*> metrocluster modify -node-name clusA-01 -node-object-limit on
  [Job 168] Job succeeded: Modify is successful
clusA::*> metrocluster modify -node-name clusA-01 -automatic-switchover-onfailure false
  [Job 308] Job succeeded: Modify is successful
clusA::> metrocluster modify -auto-switchover-failure-domain auso-on-cluster-disaster
clusA::> metrocluster modify -is-encryption-enabled true -dr-group-id 1
  [Job 206] Job succeeded: Modify is successful
