ONTAP commands
metrocluster modify
Modify MetroCluster configuration options
The metrocluster modify command modifies MetroCluster parameters for nodes in the MetroCluster configuration.
{ -auto-switchover-failure-domain <MetroCluster AUSO Failure Domain> - Cluster Level AUSO Option
This parameter specifies the configuration of automatic switchover. Modifying auto-switchover-failure-domain is not supported on a MetroCluster over IP configuration.
The parameter values are:
  • auso-on-cluster-disaster - triggers an unplanned switchover if all nodes in a DR cluster are down.
  • auso-on-dr-group-disaster - triggers an unplanned switchover if both nodes of a DR group are down.
  • auso-disabled - automatic switchover is disabled.
On a MetroCluster over IP configuration, auto-switchover-failure-domain is set to auso-disabled ; otherwise, it is set to auso-on-cluster-disaster .
A change to the parameter affects only the local cluster where the metrocluster modify command is used.
| -node-name {<nodename>|local} - Node to Change the Option On }
This parameter is used to specify the node in the cluster for which the parameter needs to be modified.
[-automatic-switchover-onfailure <true>] - Node Level AUSO Option (privilege: advanced) }
This parameter is used to enable automatic switchover on node failures. The automatic-switchover-onfailure parameter is not supported on a MetroCluster over IP configuration.
All nodes in a MetroCluster configuration must have this option enabled to enable automatic switchover on failure.
The following example shows the output of Metrocluster modification done on a node:
clusA::*> metrocluster modify -node-name clusA-01 -node-object-limit on
  [Job 168] Job succeeded: Modify is successful
clusA::*> metrocluster modify -node-name clusA-01 -automatic-switchover-onfailure false
  [Job 308] Job succeeded: Modify is successful
clusA::> metrocluster modify -auto-switchover-failure-domain auso-on-cluster-disaster
