The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node coredump segment delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a core segment
This command deletes a core segment.
-node {<nodename>|local}
- Node-
This specifies the node on which to delete the core segments.
-segment <text>
- Core Segment-
This specifies the core segment to delete. The pathname is relative to the coredump directory. If a directory is specified, all core segment files within it are deleted. If the directory is empty, it is deleted.
[-owner-node <text>]
- Node That Owns the Core Segment File-
This specifies the node that owns the core segment. Use this parameter only in takeover mode to delete a partner's coredump segment.
This deletes all core segments in the directory, core.151708240.2012-01-11.05_56_52
cluster1::> system node coredump segment delete -node node1 -segment core.151708240.2012-01-11.05_56_52
