vserver security file-directory ntfs dacl modify
Modify an NTFS security descriptor DACL entry
The vserver security file-directory ntfs dacl modify
command modifies parameters in an existing discretionary access control (DACL) entry.
You can unambiguously define which DACL entry to modify by specifying the following four parameters in the modify command:
Vserver associated with the security descriptor that contains the DACL entry
Name of the security descriptor that contains the DACL entry
Whether the DACL is an allow or deny type of DACL entry
The account name or SID to which the DACL is applied
You can modify the following parameters:
-right,-advanced-rights ,-rights-raw
-apply-to
-vserver <vserver name>
- Vserver-
Specifies the name of the Vserver associated with the security descriptor containing the discretionary access control entry whose parameters you want to modify.
-ntfs-sd <ntfs sd name>
- NTFS Security Descriptor Name-
Specifies the name of the security descriptor that contains the discretionary access control entry that you want to modify.
-access-type {deny|allow}
- Allow or Deny-
Specifies whether the discretionary access control entry that you want to modify is an
allow
ordeny
type of access control. -account <name or sid>
- Account Name or SID-
Specifies the account associated with the discretionary access control entry you want to modify. You can specify the account by using a user name or SID. You can use any of the following formats when specifying the value for this parameter:
* SID
* Domain\user-name
* user-name@Domain
* user-name@FQDNIf you specify any of the three user name formats for the value of -account, keep in mind that the value for the user name is case insensitive. - {
[-rights {no-access|full-control|modify|read-and-execute|read|write}]
- Access Rights -
Specifies the right that you want to add for the account specified in the
-account
parameter. The-rights
parameter is mutually exclusive with the-advanced-rights
and-rights-raw
parameter. If you specify the-rights
parameter, you can only specify one value.You can specify one of the following rights values:
no-access
full-control
modify
read-and-execute
read
write
[-rights-raw <Hex Integer>]
- Raw Access Rights -
Specifies the raw rights that you want to add for the account specified in the
-account
parameter. The-rights-raw
and-rights
parameter. Specify the value as a hexadecimal integer, for example:0xA10F
or0xb3ff
etc. - |
[-advanced-rights <Advanced access right>,…]
- Advanced Access Rights } -
Specifies the advanced rights that you want to add for the account specified in the
-account
parameter. The-advanced-rights
parameter is mutually exclusive with the-rights
and-rights-raw
parameter. You can specify more than one advanced-rights value by using a comma-delimited list.You can specify one or more of the following advanced rights:
read-data
write-data
append-data
read-ea
write-ea
execute-file
delete-child
read-attr
write-attr
delete
read-perm
write-perm
write-owner
full-control
[-apply-to {this-folder|sub-folders|files}]
- Apply DACL Entry-
Specifies where to apply the discretionary access control entry. You can specify more than one value by using a comma-delimited list.
You can specify one or more of the following values:
this-folder
sub-folder
files
Select one of the following combinations of values for the -apply-to
parameter for Storage-Level Access Guard (SLAG):-
this-folder, sub-folder, files
files
If you specify an invalid
-apply-to
value, this security descriptor is removed from the associated Storage-Level Access Guard (SLAG)security file-directory policy task
The following example modifies the -right
and -apply-to
parameters in the DACL entry associated to the security descriptor named “sd2” on Vserver vs1 for the "BUILTIN\Administrators" account.
cluster1::> vserver security file-directory ntfs dacl modify -ntfs-sd sd2 -access-type allow -account BUILTIN\Administrators -vserver vs1 -rights modify -apply-to this-folder,sub-folders cluster1::> vserver security file-directory ntfs dacl show -vserver vs1 -ntfs-sd sd2 -account BUILTIN\Administrators -instance Vserver: vs1 Security Descriptor Name: sd2 Allow or Deny: allow Account Name or SID: BUILTIN\Administrators Access Rights: modify Advanced Access Rights: - Apply To: this-folder, sub-folders Access Rights: modify
