vserver cifs domain preferred-dc show
PDF of this doc site
Creating your file...
Display a list of preferred domain controllers
The vserver cifs domain preferred-dc show
command displays lists of preferred domain controllers by Vserver and domain.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
This parameter specifies the name of the Vserver for which you want to display preferred domain controllers.
[-domain <TextNoCase>]
- Fully Qualified Domain Name-
This parameter specifies the fully-qualified name of the domain of the domain controllers to display.
[-preferred-dc <InetAddress>,…]
- Preferred Domain Controllers-
This parameter specifies a comma-delimited list of IP addresses for domain controllers to display.
The following example displays all preferred domain controllers for all Vservers:
cluster1::> vserver cifs domain preferred-dc show Vserver Domain Name Preferred Domain Controllers -------------- ----------------------------- ---------------------------------- vs1 example.com 192.168.0.100, 192.168.0.101
