autobalance aggregate config modify
Modify the Auto Balance Aggregate feature configuration
The autobalance aggregate config modify command allows the user to customize the parameters that determine when volumes should be considered for automatic move or recommendation by the Auto Balance Aggregate feature.
[-is-enabled {true|false}]- Is the Auto Balance Aggregate Feature Enabled (privilege: advanced)-
This specifies whether the Auto Balance Aggregate feature is enabled and running.
[-aggregate-unbalanced-threshold-percent <integer>]- Threshold When Aggregate Is Considered Unbalanced (%) (privilege: advanced)-
This specifies the space used threshold percentage that will cause the Auto Balance Aggregate feature to consider an aggregate as unbalanced.
[-aggregate-available-threshold-percent <integer>]- Threshold When Aggregate Is Considered Balanced (%) (privilege: advanced)-
This specifies the threshold percentage which will determine if an aggregate is a target destination for a move. The Auto Balance Aggregate feature will attempt to move volumes from an unbalanced aggregate until it is under this percentage.
The following example displays a modification for the default configuration of the Auto Balance Aggregate feature
cluster1::*> autobalance aggregate config show
Is the Auto Balance Aggregate Feature Enabled: false
Threshold When Aggregate Is Considered Unbalanced (%): 70
Threshold When Aggregate Is Considered Balanced (%): 40
cluster1::*> autobalance aggregate config modify -is-enabled true
Is the Auto Balance Aggregate Feature Enabled: true
