security key-manager show
PDF of this doc site
Creating your file...
(DEPRECATED)-Display key management servers
This command is deprecated and may be removed in a future release. Use security key-manager external show instead. |
This command displays the key management servers configured on the cluster. This command is not supported when onboard key management is enabled.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-status ]
If you specify this parameter, the command displays the status of each key management server.
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
This parameter specifies the name of the node that you want to retrieve key management server status for. If parameter is not specified, all nodes will retrieve the key management servers status.
[-address <IP Address>]
- IP Address-
Shows only a key management server registered with the input address. It is also possible to show multiple key management servers.
[-server-port <integer>]
- Server TCP Port-
If you specify this parameter, the command displays only key servers listening on this port.
The following example lists all configured key management servers:
cluster-1::> security key-manager show Node Registered Key Manager ---------------------- --------------------------- node1 10.225.89.33 node2 10.225.89.33
The following example lists all configured key management servers, the TCP port on which those servers are expected to listen for incoming KMIP connections, and their server status:
cluster-1::> security key-manager show -status Node Port Registered Key Manager Status ---------------------- ------ --------------------------- --------------- node1 5696 10.225.89.33 available node2 5696 10.225.89.33 available
