ONTAP 9.12.1 commands
security key-manager show
(DEPRECATED)-Display key management servers
Note This command is deprecated and may be removed in a future release. Use security key-manager external show instead.
This command displays the key management servers configured on the cluster. This command is not supported when the Onboard Key Manager is enabled.
{ [-fields <fieldname>,…​]
| [-status ]
If you specify this parameter, the command displays the status of each key management server.
| [-instance ] }
[-node {<nodename>|local}] - Node
This parameter specifies the name of the node that you want to retrieve key management server status for. If parameter is not specified, all nodes will retrieve the key management servers status.
[-address <IP Address>] - IP Address
Shows only a key management server registered with the input address. It is also possible to show multiple key management servers.
[-server-port <integer>] - Server TCP Port
If you specify this parameter, the command displays only key servers listening on this port.
The following example lists all configured key management servers:
cluster-1::> security key-manager show
Node                    Registered Key Manager
node1                   10.225.89.33
node2                   10.225.89.33
The following example lists all configured key management servers, the TCP port on which those servers are expected to listen for incoming KMIP connections, and their server status:
cluster-1::> security key-manager show -status
Node                    Port    Registered Key Manager       Status
node1                   5696    10.225.89.33                 available
node2                   5696    10.225.89.33                 available
