system license capacity show
(DEPRECATED)-Show license capacity status
This command is deprecated and may be removed in a future release of Data ONTAP. Use the "system license show-status " command. |
The system license capacity show
command displays the information about the licenses in the system that are specifically related to storage capacity limits.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-serial-number <Node Serial Number>]
- Serial Number-
If you use this parameter, the command displays information only about the capacity-related licenses that matches the serial number you specify.
[-package <Licensable Package>]
- Package-
If you use this parameter, the command displays information only about the package you specify.
[-owner <text>]
- Owner-
If you use this parameter, the command displays information only about the capacity-related licenses that have the owner you specify.
[-max-capacity {<integer>[KB|MB|GB|TB|PB]}]
- Maximum Capacity-
If you use this parameter, the command displays information only about the capacity-related licenses that have the maximum amount of attached storage capacity you specify.
[-current-capacity {<integer>[KB|MB|GB|TB|PB]}]
- Current Capacity-
If you use this parameter, the command displays information only about the capacity-related licenses that apply to the node with the current attached capacity you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>]
- Expiration Date-
If you use this parameter, the command displays information only about the capacity-related licenses that have the expiration date you specify.
[-reported-state {evaluation|warning|missing|enforcement|installed}]
- Reported State-
If you use this parameter, the command displays information only about the capacity-related licenses that have the reported state you specify.
[-node {<nodename>|local}]
- Node Name-
If you use this parameter, the command displays information only about the capacity-related licenses that apply to the node you specify.
The following example displays information about all capacity-related licensed packages in the cluster, for a hypothetical cluster of four nodes:
Note that for some nodes below, the maximum capacity is displayed as "-" (meaning "unlimited"). This happens when there is no capacity license for the node - the node is operating with a limited-time temporary capacity license.
cluster1::> system license capacity show Node: node1 Serial Number: 1-81-0000000000001234567890123456 Max Current Package Capacity Capacity Expiration ------------------------ -------- -------- ------------------- Select 2TB 15.81GB 4/11/2016 00:00:00 Node: node2 Serial Number: 1-81-0000000000000000000123456788 Max Current Package Capacity Capacity Expiration ------------------------ -------- -------- ------------------- Select - 10.40TB 4/11/2016 00:00:00 Node: node3 Serial Number: 1-81-0000000000000000000123456789 Max Current Package Capacity Capacity Expiration ------------------------ -------- -------- ------------------- Select - 10.40TB 4/11/2016 00:00:00 Node: node4 Serial Number: 1-81-0000000000001234567890123456 Max Current Package Capacity Capacity Expiration ------------------------ -------- -------- ------------------- Select 2TB 15.81GB 4/11/2016 00:00:00
