security session limit show
Show default session limits
This command shows the default management session limits that have been configured for each interface and category.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-interface {cli|ontapi|rest}] - Interface
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) to which the limit applies.
[-category {application|location|request|user|vserver}] - Category
Selects the sessions that match this parameter value. This identifies the category for the limit. The following categories are supported: application, location, request, user, and Vserver.
[-max-active-limit <integer>] - Max-Active Limit
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the default limits for management sessions.
cluster1::> security session limit show
Interface Category    Max-Active
cli       user                 2
cli       vserver              4
ontapi    vserver              2
3 entries were displayed.
