system node external-cache show
PDF of this doc site
Creating your file...
Display external cache settings.
The system node external-cache show
command displays external-cache information for each of the nodes available.
[-fields <fieldname>,…]
Valid values for this option are
{node|is-enabled|is-rewarm-enabled|is-mbuf-inserts-enabled|pcs-size|is-hya-enabled}
. Specifying the value will display all entries that correspond to it. - |
[-instance ]
This option does not need an input value. Specifying this option will display the information about all the entries.
[-node {<nodename>|local}]
- Node-
Specify this parameter to display external-cache parameters that match the specified node.
[-is-enabled {true|false}]
- Is Enabled?-
Valid values for this option are true and false. Specifying the value will display all entries that correspond to it.
[-is-rewarm-enabled {true|false}]
- Is Rewarm On?-
[-is-mbuf-inserts-enabled {true|false}]
- Is Mbuf Inserts On?-
[-pcs-size <integer>]
- PCS Size-
Valid values for this option are integers between 16 and 16383. Specifying the value will display all entries that correspond to it.
[-is-hya-enabled {true|false}]
- Is HyA Caching Enabled?-
cluster1::> system node external-cache show -node node1 Node: node1 Is Enabled: false Is rewarm on: false Is Mbuf inserts on: true PCS size: 256 Is hya caching enabled: true
Displays the external-cache information about node1
in a list format.
