system health config show
Display system health configuration
The system health config show command displays the configuration and status of each health monitor in the cluster. The command shows a health status for each health monitor. The health status is an aggregation of the subsystem health for each subsystem that the health monitor monitors. For example, if a health monitor monitors two subsystems and the health status of one subsystem is "ok" and the other is "degraded", the health status for the health monitor is "degraded".
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to list the health monitors present on the specified node.
[-monitor <hm_type>]- Monitor-
Use this parameter to display the health monitors with the specified monitor name.
[-subsystem <hm_subsystem>,…]- Subsystem-
Selects the health monitors with the specified subsystems.
[-health {ok|ok-with-suppressed|degraded|unreachable|unknown}]- Health-
Selects the health monitors with the specified health status.
[-mon-version <text>]- Monitor Version-
Selects the health monitors with the specified monitor version.
[-pol-version <text>]- Policy File Version-
Selects the health monitors with the specified health monitor policy version.
[-context {Node |Cluster}]- Context-
Selects the health monitors with the specified running context.
[-aggregator <hm_type>]- Aggregator-
Selects the health monitors with the specified aggregator.
[-resources <text>,…]- Resource-
Selects the health monitors with the specified resource name.
[-init-state {Invalid|Initailizing|Initialized|Starting_Discovery|Starting_Re-Discovery|Discovery_Done_Partially|Discovery_Done}]- Subsystem Initialization Status-
Selects the health monitors with the specified subsystem initialization state.
[-sub-pol-versions <text>]- Subordinate Policy Versions-
Selects the health monitors with the specified subordinate policy version.
The example below displays information about health monitor configuration:
cluster1::> system health config show Node Monitor Subsystem Health ------------- ---------------------- ----------------- ------------------ node1 node-connect SAS-connect degraded node1 system-connect SAS-connect degraded node1 system SAS-connect degraded
The example below displays detailed information about health monitor configuration:
cluster1::> system health config show -instance
Node: node1
Monitor: node-connect
Subsystem: SAS-connect
Health: degraded
Monitor Version: 1.0
Policy File Version: 1.0
Context: node_context
Aggregator: system-connect
Resource: SasAdapter, SasDisk, SasShelf
Subsystem Initialization Status: initialized
Subordinate Policy Versions: 1.0 SAS, 1.0 SAS multiple adapters
