ONTAP commands
metrocluster configuration-settings dr-group show
Display the DR groups in a MetroCluster setup
The metrocluster configuration-settings dr-group show command displays the DR groups and their nodes.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
If this parameter is specified, the command displays detailed information about all entries.
[-dr-group-id <integer>] - DR Group ID
If this parameter is specified, the command displays information for the matching DR group.
[-cluster-uuid <UUID>] - Cluster UUID
If this parameter is specified, the command displays information for the matching cluster uuid.
[-cluster <Cluster name>] - Cluster Name
If this parameter is specified, the command displays information for the specified cluster.
[-node-uuid <UUID>] - Node UUID
If this parameter is specified, the command displays information for the matching nodes uuid.
[-node <text>] - Node Name
If this parameter is specified, the command displays information for the matching nodes.
[-dr-partner-node-uuid <UUID>] - DR Partner Node UUID
If this parameter is specified, the command displays information for the matching DR partner node uuid.
[-dr-partner-node <text>] - DR Partner Node Name
If this parameter is specified, the command displays information for the matching DR partner nodes.
The following example illustrates the display of DR group configuration in a four-node MetroCluster setup:
clusA::>  metrocluster configuration-settings dr-group show
DR Group ID Cluster                    Node               DR Partner Node
1           clusA
                                       A1                 B1
                                       A2                 B2
            clusB
                                       B2                 A2
                                       B1                 A1
4 entries were displayed.
