metrocluster configuration-settings dr-group show
Display the DR groups in a MetroCluster over IP setup
The metrocluster configuration-settings dr-group show
command displays the DR groups and their nodes in the MetroCluster over IP setup.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays only the fields that you specify. - |
[-instance ]
If this parameter is specified, the command displays detailed information about all entries.
[-dr-group-id <integer>]
- DR Group ID-
If this parameter is specified, the command displays information for the matching DR group.
[-cluster-uuid <UUID>]
- Cluster UUID-
If this parameter is specified, the command displays information for the matching cluster uuid.
[-cluster <Cluster name>]
- Cluster Name-
If this parameter is specified, the command displays information for the specified cluster.
[-node-uuid <UUID>]
- Node UUID-
If this parameter is specified, the command displays information for the matching nodes uuid.
[-node <text>]
- Node Name-
If this parameter is specified, the command displays information for the matching nodes.
[-dr-partner-node-uuid <UUID>]
- DR Partner Node UUID-
If this parameter is specified, the command displays information for the matching DR partner node uuid.
[-dr-partner-node <text>]
- DR Partner Node Name-
If this parameter is specified, the command displays information for the matching DR partner nodes.
The following example illustrates the display of DR group configuration in a four-node MetroCluster setup:
clusA::> metrocluster configuration-settings dr-group show DR Group ID Cluster Node DR Partner Node ----------- -------------------------- ------------------ ------------------ 1 clusA A1 B1 A2 B2 clusB B2 A2 B1 A1 4 entries were displayed.
