metrocluster configuration-settings dr-group show
Display the DR groups in a MetroCluster over IP setup
The metrocluster configuration-settings dr-group show command displays the DR groups and their nodes in the MetroCluster over IP setup.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>,…parameter, the command displays only the fields that you specify.
- | [-instance ]}
If this parameter is specified, the command displays detailed information about all entries.
- [-dr-group-id <integer>]- DR Group ID
If this parameter is specified, the command displays information for the matching DR group.
- [-cluster-uuid <UUID>]- Cluster UUID
If this parameter is specified, the command displays information for the matching cluster uuid.
- [-cluster <Cluster name>]- Cluster Name
If this parameter is specified, the command displays information for the specified cluster.
- [-node-uuid <UUID>]- Node UUID
If this parameter is specified, the command displays information for the matching nodes uuid.
- [-node <text>]- Node Name
If this parameter is specified, the command displays information for the matching nodes.
- [-dr-partner-node-uuid <UUID>]- DR Partner Node UUID
If this parameter is specified, the command displays information for the matching DR partner node uuid.
- [-dr-partner-node <text>]- DR Partner Node Name
If this parameter is specified, the command displays information for the matching DR partner nodes.
The following example illustrates the display of DR group configuration in a four-node MetroCluster setup:
clusA::>  metrocluster configuration-settings dr-group show
DR Group ID Cluster                    Node               DR Partner Node
1           clusA
                                       A1                 B1
                                       A2                 B2
            clusB
                                       B2                 A2
                                       B1                 A1
4 entries were displayed.
 PDFs
PDFs
