ONTAP commands
volume inode-upgrade show
Display Inode Upgrade Progress
The volume inode-upgrade show command displays information about volumes in the middle of the inode upgrade process. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the default fields about all volumes in the middle of the inode upgrade process. Default fields are vserver , volume , aggregate , status , scan-percent , remaining-time , space-needed , and scanner-progress .
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed.
| [-instance ] }
If this parameter is specified, the command displays information about all entries.
[-vserver <vserver name>] - Vserver (privilege: advanced)
If this parameter and the -volume parameter are specified, the command displays detailed information about the specified volume. If this parameter is specified by itself, the command displays information about volumes on the specified Vserver.
[-volume <volume name>] - Volume (privilege: advanced)
If this parameter and the -vserver parameter are specified, the command displays detailed information about the specified volume. If this parameter is specified by itself, the command displays information about all volumes that match the specified name.
[-node <nodename>] - Node Name (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes that are located on the specified storage system.
[-vol-dsid <integer>] - Volume DSID (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes that match the specified data set ID.
[-vol-uuid <UUID>] - Volume UUID (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes that match the specified UUID.
[-volume-msid <integer>] - Volume MSID (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes that match the specified master data set ID.
[-vserver-uuid <UUID>] - Vserver UUID (privilege: advanced)
If this parameter is specified, the command displays information only about the volume on the Vserver that has the specified UUID.
[-aggregate <aggregate name>] - Aggregate Name (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes that are located on the specified storage aggregate.
[-aggregate-uuid <UUID>] - Aggregate UUID (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes that are located on the storage aggregate with the specified UUID.
[-status {pending|scanning|suspended-initalizing|suspended|cleanup-pending|cleanup|cleanup-done|suspended-aborting|suspended-removing|suspended-while-removing|suspended-ironing}] - Upgrade Status (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes that match the specified inode upgrade status.
[-scan-percent <percent>] - Upgrade Scan Percent Complete (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes that match the specified inode upgrade progress percentage.
[-space-needed {<integer>[KB|MB|GB|TB|PB]}] - Space Needed to Complete Upgrade (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes where the space needed to complete the upgrade process match the specified size.
[-remaining-time <[<integer>h][<integer>m][<integer>s]>] - Remaining Upgrade Time (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes where the remaining time to complete the inode upgrade process match the specified time.
[-scanner-progress <text>] - Scanner Progress (privilege: advanced)
If this parameter is specified, the command displays information only about the volume or volumes where the progress of the inode upgrade process match the input.
The following example displays information about all volumes in the middle of the inode upgrade process on the Vserver named vs0:
cluster1::> volume inode-upgrade show -vserver vs0
Vserver Volume Aggregate Status %Complete Time      Space  Inode
                                          Remaining Needed Progress
vs0     vol1   aggr1     pending   0%     -         3.07MB Public : Inode 0 out of 3822
