security key-manager external enable
Enable External Key Management
This command enables the external key manager associated with the given Vserver. This command is not supported when a key manager for the given Vserver is already enabled.
-vserver <vserver name>
- Vserver Name-
Use this parameter to specify the Vserver on which the external key manager is to be enabled.
-key-servers <Hostname and Port>,…
- List of External Key Management Servers-
Use this parameter to specify the list of up to four key management servers that the external key manager uses to store keys.
-client-cert <text>
- Name of the Client Certificate-
Use this parameter to specify the unique name of the client certificate that the key management servers use to ensure the identity of Data ONTAP.
-server-ca-certs <text>,…
- Names of the Server CA Certificates-
Use this parameter to specify the unique names of server-ca certificates that Data ONTAP uses to ensure the identify of the key management servers.
The following example enables the external key manager for Vserver cluster-1. The command includes three key management servers. The first key server's hostname is ks1.local and is listening on port 15696. The second key server's IP address is 10.0.0.10 and is listening on the default port 5696. The third key server's IPv6 address is fd20:8b1e:b255:814e:32bd:f35c:832c:5a09, and is listening on port 1234.
cluster-1::> security key-manager external enable -vserver cluster-1 -key-servers ks1.local:15696,10.0.0.10,[fd20:8b1e:b255:814e:32bd:f35c:832c:5a09]:1234 -client-cert AdminVserverClientCert -server-ca-certs ServerCaCert1,ServerCaCert2
