ONTAP commands
event snmphistory show
(DEPRECATED)-Display a list of SNMP trap history records
Note This command has been deprecated. It may be removed from a future release of Data ONTAP. Instead, use the "event notification history" command set.
The event snmphistory show command displays a list of event notifications that have been sent to SNMP traps. The command output depends on the parameters specified with the command. By default, the command displays general information about all trap-history records.
To display detailed information about a specific trap-history record, run the command with the -seqnum parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the trap-history records that match this parameter value (text pattern).
[-seqnum <Sequence Number>] - Sequence Number
Selects the trap-history records that match this parameter value (sequence number).
[-message-name <Message Name>] - Message Name
Selects the trap-history records that match this parameter value.
[-address <text>,…​] - SNMP Client Address
Selects the trap-history records that match this parameter value (IP address).
[-time <MM/DD/YYYY HH:MM:SS>] - Transmission Time
[-message <text>] - Alert Message
[-previous-time <MM/DD/YYYY HH:MM:SS>] - Previous Transmission Time
[-num-drops-since-previous <integer>] - Number of Drops Since Previous Transmission
Selects the trap-history records that match this parameter value (number of event drops since last transmission).
The following example displays information about all SNMP trap-history records:
cluster1::> event snmphistory show
Seq # Message Name          Address   Node  Time
12481 raid.mirror.restrict  10.0.2.20 node0 4/14/2008 15:11:04
12482 aggrcopy.dst.noMemory 10.0.2.20 node0 4/14/2008 14:52:54
12483 raid.mirror.restrict  10.0.2.21 node1 4/14/2008 14:41:04
