vserver snapdiff-rpc-server show
Display the SnapDiff RPC server configurations of Vservers
The vserver snapdiff-rpc-server show command displays the state of the SnapDiff RPC server for all the Vservers. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all the configured Vservers:
Vserver name
Whether SnapDiff RPC server access is enabled
You can specify additional parameters to display only the information that matches those parameters. For instance, to display the information only for the Vservers that have access enabled, enter the command with the -state on parameter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver (privilege: advanced)-
If you specify this parameter, the command displays information only about the specified Vserver.
[-state {on|off}]- SnapDiff RPC Server state (privilege: advanced)-
If you specify this parameter, the command displays information only about the specified SnapDiff RPC server state.
The following example displays information about all the Vservers with SnapDiff RPC server configured:
cluster1::> vserver snapdiff-rpc-server show Vserver SnapDiff RPC Server State ----------- -------------------------- vs0 on vs1 off 2 entries were displayed.
