vserver nfs pnfs devices cache show
Display the device cache
The `vserver nfs pnfs devices cache show` command displays the device cache.
[-fields <fieldname>,…]
If you specify the
-fields
parameter, the command only displays the fields that you specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all entries. [-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays information only about the pNFS devices cache present on the node.
[-vserver <vserver name>]
- Vserver Name-
If you specify this parameter, the command displays information only about the Vserver that has the pNFS devices cache.
