ONTAP commands
vserver nfs pnfs devices cache show
Display the device cache
The `vserver nfs pnfs devices cache show` command displays the device cache.
{ [-fields <fieldname>,…​]
If you specify the -fields parameter, the command only displays the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
[-node {<nodename>|local}] - Node (privilege: advanced)
If you specify this parameter, the command displays information only about the pNFS devices cache present on the node.
[-vserver <vserver name>] - Vserver Name (privilege: advanced)
If you specify this parameter, the command displays information only about the Vserver that has the pNFS devices cache.
