cluster quorum-service options modify
Modify the settings for cluster quorum-service
The cluster quorum-service options modify command modifies the values of cluster quorum services options.
[-ignore-quorum-warning-confirmations {true|false}] - Whether or Not Warnings Are Enabled
Specifies whether cluster quorum warnings and confirmations should be ignored when cluster operations could negatively impact cluster quorum:
The default setting is false.
The following example shows the usage of this command:
cluster1::> set advanced
Warning: These advanced commands are potentially dangerous; use them only when
         directed to do so by NetApp personnel.
         Do you want to continue? {y|n}: y
cluster1::*> cluster quorum-service options modify -ignore-quorum-warning-confirmations true
