cluster quorum-service options modify
Modify the settings for cluster quorum-service
The cluster quorum-service options modify
command modifies the values of cluster quorum services options.
[-ignore-quorum-warning-confirmations {true|false}]
- Whether or Not Warnings Are Enabled-
Specifies whether cluster quorum warnings and confirmations should be ignored when cluster operations could negatively impact cluster quorum:
Halting a node (system node halt )
Rebooting a node (system node reboot )
Issuing a planned takeover (storage failover takeover )
The default setting is false.
The following example shows the usage of this command:
cluster1::> set advanced Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel. Do you want to continue? {y|n}: y cluster1::*> cluster quorum-service options modify -ignore-quorum-warning-confirmations true
