storage disk removeowner
Remove disk ownership
The storage disk removeowner command removes ownership from a specified disk. Then disk can then be reassigned to a new owner.
-disk <disk path name> - Disk Name
This specifies the disk whose ownership is to be removed.
{ [-root <true>] - Root Partition of Root-Data/Root-Data1-Data2 Partitioned Disk
This optional parameter removes ownership of the root partition of a root-data/root-data1-data2 partitioned disk. You cannot use this parameter with disks that are part of a storage pool. The default value is false .
| [-data <true>] - Data Partition of Root-Data Partitioned Disk
This optional parameter removes ownership of the data partition of a root-data partitioned disk. You cannot use this parameter with a root-data1-data2 partitioned disk or disks that are part of a storage pool. The default value is false .
| [-data1 <true>] - Data1 Partition of a Root-Data1-Data2 Partitioned Disk
This optional parameter removes ownership of the data1 partition of a root-data1-data2 partitioned disk. You cannot use this parameter with a root-data partitioned disk or disks that are part of a storage pool. The default value is false .
| [-data2 <true>] - Data2 Partition of a Root-Data1-Data2 Partitioned Disk }
This optional parameter removes ownership of the data2 partition of a root-data1-data2 partitioned disk. You cannot use this parameter with a root-data partitioned disk or disks that are part of a storage pool. The default value is false .
The following example removes the ownership from a disk named 1.1.27.
cluster1::> storage disk removeowner -disk 1.1.27
The following example removes ownership of the root partition on disk 1.1.16.
cluster1::> storage disk removeowner -disk 1.1.16 -root true
The following example removes ownership of the data partition on disk 1.1.16.
cluster1::> storage disk removeowner -disk 1.1.16 -data true
The following example removes ownership of the data1 partition on disk 1.1.23.
cluster1::> storage disk removeowner -disk 1.1.23 -data1 true
The following example removes ownership of the data2 partition on disk 1.1.23.
cluster1::> storage disk removeowner -disk 1.1.23 -data2 true
