job stop
Stop a job
-id <integer>
- Job ID-
The numeric ID of the job to stop. A job ID is a positive integer.
[-vserver <vserver name>]
- Owning Vserver-
Use this parameter to specify the name of the Vserver that owns the job.
The following example stops the job that has ID 101:
cluster1::> job stop -id 101
