statistics system show
System utilization metrics for the cluster
This command continuously displays performance data for cluster at a regular interval. The command output displays data in the following columns:
  • System - cluster name.
  • CPU (%) - CPU utilization.
  • Total Ops - total number of operations per second.
  • Latency(ms) - average latency for an operation in milliseconds.
[-system <text>] - System
Selects the cluster for which you want to display performance data.
[-sort-key <text>] - Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer> - Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer> - Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer> - Maximum Number of Instances
Specifies the maximum number of systems to display. The default setting is 25.
The following example displays system statistics:
cluster1::> statistics system show
cluster1 : 12/31/2013 16:00:04
         CPU *Total Latency
  System (%)    Ops    (ms)
 Cluster  76    113       -
