vserver san prepare-to-downgrade
Restore the SAN Configurations to Earlier Release of Data ONTAP Version.
This command initiates the procedure to restore the configuration to Earlier Release of Data ONTAP Version.
As part of this command, capability for making SAN LIF offline if placed on the DR auxiliary partner as part of LIF placement in Metrocluster environment will be disabled.
-feature-set <ClusterVersion> - Disable the capability introduced in the Data ONTAP Version
Specifies the DATA ONTAP Cluster Version from revert to.
cluster1::> vserver san prepare-to-downgrade -feature-set 8.3.1
Clears the SAN configuration to make it compatible to an earlier DATA ONTAP release.
