The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver san prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Restore the SAN Configurations to Earlier Release of Data ONTAP Version.
This command initiates the procedure to restore the configuration to Earlier Release of Data ONTAP Version.
As part of this command, capability for making SAN LIF offline if placed on the DR auxiliary partner as part of LIF placement in Metrocluster environment will be disabled.
-feature-set <ClusterVersion>
- Disable the capability introduced in the Data ONTAP Version-
Specifies the DATA ONTAP Cluster Version from revert to.
cluster1::> vserver san prepare-to-downgrade -feature-set 8.3.1
Clears the SAN configuration to make it compatible to an earlier DATA ONTAP release.
