autobalance aggregate config show
PDF of this doc site
Creating your file...
Your file is ready
Display the Auto Balance Aggregate feature configuration
The autobalance aggregate config show
command displays information about parameters that determine when volumes should be considered for automatic move or recommendation by the Auto Balance Aggregate feature.
The following example displays the default configuration for the Auto Balance Aggregate feature
cluster1::*> autobalance aggregate config show Is the Auto Balance Aggregate Feature Enabled: false Threshold When Aggregate Is Considered Unbalanced (%): 70 Threshold When Aggregate Is Considered Balanced (%): 40
