autobalance aggregate config show
Display the Auto Balance Aggregate feature configuration
The autobalance aggregate config show command displays information about parameters that determine when volumes should be considered for automatic move or recommendation by the Auto Balance Aggregate feature.
The following example displays the default configuration for the Auto Balance Aggregate feature
cluster1::*> autobalance aggregate config show
Is the Auto Balance Aggregate Feature Enabled: false
Threshold When Aggregate Is Considered Unbalanced (%): 70
Threshold When Aggregate Is Considered Balanced (%): 40
