system license show
PDF of this doc site
Creating your file...
Display licenses
The ` system license show ` command displays the information about licenses in the system.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-serial-number <text>]
- Serial Number-
If you use this parameter, the command displays information only about the licenses that matches the serial number you specify.
[-package <Licensable Package>]
- Package-
If you use this parameter, the command displays information only about the specified package.
[-owner <text>]
- Owner-
If you use this parameter, the command displays information only about the packages that matches the owner name you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>]
- Expiration-
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
[-description <text>]
- Description-
If you use this parameter, the command displays information only about the licenses that matches the description you specify.
[-type {license|site|demo|subscr|capacity|capacity-per-term|enabled}]
- Type-
If you use this parameter, the command displays information only about the licenses that have the license type you specify.
[-customer-id <text>]
- Customer ID-
If you use this parameter, the command displays information only about the licenses that have the customer-id you specify.
[-installed-license <text>]
- Installed License Name-
If you use this parameter, the command displays information only about the licenses that match the installed license you specify.
[-host-id <text>]
- Host Id-
If you use this parameter, the command displays information only about the license that have the host id you specify.
[-capacity {<integer>[KB|MB|GB|TB|PB]}]
- License Capacity-
If you use this parameter, the command displays information only about the licenses that match the capacity you specify.
The following example displays information about all licensed packages in the cluster:
cluster1::> system license show Serial Number: 1-81-0000000000000001122334455 Owner: node2 Installed License: Legacy Key Capacity: - Package Type Description Expiration ----------------- -------- --------------------- ------------------- NFS license NFS License - CIFS license CIFS License - iSCSI license iSCSI License - SnapRestore license SnapRestore License - FlexClone license FlexClone License - S3 license S3 License - Serial Number: 123456789 Owner: node1 Installed License: Core Bundle Capacity: 10TB Package Type Description Expiration ----------------- -------- --------------------- ------------------- NFS capacity NFS License - CIFS capacity CIFS License - iSCSI capacity iSCSI License - SnapRestore capacity SnapRestore License - FlexClone capacity FlexClone License - S3 capacity S3 License - 12 entries were displayed.
