system license show
Display licenses
The ` system license show ` command displays the information about licenses in the system.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-serial-number <text>]- Serial Number-
If you use this parameter, the command displays information only about the licenses that matches the serial number you specify.
[-package <Licensable Package>]- Package-
If you use this parameter, the command displays information only about the specified package.
[-owner <text>]- Owner-
If you use this parameter, the command displays information only about the packages that matches the owner name you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>]- Expiration-
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
[-description <text>]- Description-
If you use this parameter, the command displays information only about the licenses that matches the description you specify.
[-type {license|site|demo|subscr|capacity|capacity-per-term}]- Type-
If you use this parameter, the command displays information only about the licenses that have the license type you specify.
[-legacy {yes|no}]- Legacy-
If you use this parameter, the command displays information only about the licenses that matches the legacy field you specify.
[-customer-id <text>]- Customer ID-
If you use this parameter, the command displays information only about the licenses that have the customer-id you specify.
[-installed-license <text>]- Installed License Name-
If you use this parameter, the command displays information only about the licenses that match the installed license you specify.
[-host-id <text>]- Host Id-
If you use this parameter, the command displays information only about the license that have the host id you specify.
[-capacity {<integer>[KB|MB|GB|TB|PB]}]- License Capacity-
If you use this parameter, the command displays information only about the licenses that match the capacity you specify.
The following example displays information about all licensed packages in the cluster:
cluster1::> system license show Serial Number: 1-80-000011 Owner: cluster1 Installed License: - Capacity: - Package Type Description Expiration ----------------- -------- --------------------- ------------------- Base site Cluster Base License - Serial Number: 1-81-0000000000000001122334455 Owner: node2 Installed License: Legacy Key Capacity: - Package Type Description Expiration ----------------- -------- --------------------- ------------------- NFS license NFS License - CIFS license CIFS License - iSCSI license iSCSI License - SnapRestore license SnapRestore License - FlexClone license FlexClone License - S3 license S3 License - Serial Number: 123456789 Owner: node1 Installed License: Core Bundle Capacity: 10TB Package Type Description Expiration ----------------- -------- --------------------- ------------------- NFS capacity NFS License - CIFS capacity CIFS License - iSCSI capacity iSCSI License - SnapRestore capacity SnapRestore License - FlexClone capacity FlexClone License - S3 capacity S3 License - 13 entries were displayed.
